Actual CPU cooler headroom/sizes
Go to solution Solved by tryphaa,
You will be fine.
Hey guys! First-time builder here. I'm looking to use a Noctua D14 for my CPU cooler in the Fractal Design R4 case. I originally wanted to use the non-windowed black Nanoxia Deep Silence 1 because I planned to water cool at some point in the long term, but its hard to find and only has x2 120mm front intakes compared to the x2 140s of the R4 (better for short-mid term).
Newegg says the R4 has 170mm of space for the heatsink, and the D14 is 160mm tall. Does the case's 170mm listed space already take into account the space the motherboard and CPU will take up, or is that value non-standard leaving me with only 10mm for my CPU/motherboard?
If it won't fit, I'll probably just wait for more of the DS1 black version or go with the white version since the DS1 has 15mm more headroom than the R4.
i7-4790K | Gigabyte G1 Gaming GTX 970 | G.Skill Ripjaws X Series 16GB (2 x 8GB)
Gigabyte GA-Z97MX-Gaming 5 | Corsair 350D | 256GB Crucial MX100 / 1TB WD Blue | Corsair RM 650 | NH-U12S
http://pcpartpicker.com/p/9XN2dC | http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Deil_Grist
Yes, it does account for it. It easily fits.
The NH-D14 will fit in the R4
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
You will be fine.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
Sweet! Thanks for letting me know, everyone.
