I just finished my friends pc and it booted up fine but now it's a black screen with a white line on the top like it's typing. Can someone please help me get my friends pc up and running.
Specs are
Asus tuf am4 motherboard
Ryzen 5 3600
MSI GTX 1070
Corsair vengeance 16gbs ram
https://linustechtips.com/topic/1176010-need-help/
Did the motherboard box have a 'Ryzen 3000 desktop ready' image on it?
B450M DS3H (rev. 1.0) | Moederbord - GIGABYTE Netherlands
https://linustechtips.com/topic/1176010-need-help/#findComment-13466658
Did you install windows?
https://linustechtips.com/topic/1176010-need-help/#findComment-13466661
4 minutes ago, tylerharding69 said:
Have not go that far just turned it on and went to bios now still on black screen with white line
As in when you try to go into your bios, it doesn't enter the bios but stays stagnant on the screen you're describing?
https://linustechtips.com/topic/1176010-need-help/#findComment-13466719
I may have found the issue. The motherboard and cpu and not for the same gen. Could is 3rd gen and motherboard is for 2nd gen
https://linustechtips.com/topic/1176010-need-help/#findComment-13466807
What motherboard is it? You didn't specify
https://linustechtips.com/topic/1176010-need-help/#findComment-13466843
18 hours ago, tylerharding69 said:
No
Then you need to update the BIOS of the board.
Request an AMD bootkit via the RMA process or get your hands on a 2nd gen/1st gen CPU to update it with.
https://linustechtips.com/topic/1176010-need-help/#findComment-13469408
