172mm max heigh cpu cooler based on your case
Get a noctua NH-D15 and never worry about buying a cpu cooler for the next decade and can cool the hottest desktop processors
https://www.google.com/amp/s/www.newegg.com/amp/noctua-nh-d15-chromax-black/p/13C-0005-001H5
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459101
totaly agree watch linus video regarding this where he will go into more detail why
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459115
That thing is so wide though? will that fit? were do you even place it?
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459120
Probably only thing to be mindful of is top fan clearance and your ram. If it's not low profile it may not work.
Something like a Dark Rock Pro 4 or Noctua N4-U12 may be more flexible, or your choice of 240mm aio.
I don't recommend aio though because they aren't an investment and aren't designed to last more that three or so years; a good tower will last almost forever.
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459138
20 minutes ago, Ulol60 said:
What is a good CPU cooler for i5 6600k and that will fit inside Fractal Design Meshify C Mini. My CPU Is always around 72C without overclocking
Jesus christ. Always?! As in, not under load? You might not need a new cooler. You might just need to reapply thermal paste and reseat your current one. No cooler works that poorly, even the $5 ones on aliexpress.
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459150
Will the Noctua NH-U12S work you think?
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459151
It's the one that came along i believe? but not from the i5 but from an i3 like 10 years ago or something... constant 2000 RPM 😞
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459156
what top cooler do you have and what ram do you have
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459157
Regarding Meshify C mini and Noctu NH-D15:
2 points·3 months ago
Can confirm a NH-D15 fits inside a normal Meshify C case which also has 172mm of clearance. I have both fans installed, however only because my RAM is very low profile (Vengeance LPX). In your situation because your RAM is tall, you will have to remove one fan that hangs over the RAM. However do not let this put you off from buying it as with just 1 fan the performance is incredibly similar."
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459165
Okay before you spend the money, reseat it and clean the fan just to be sure. That's still insane, unless somehow those coolers were just terrible, and I mean so terrible as to be borderline unusable, but I know they weren't.
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459180
How does one reset the fan?
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459182
It'd work fine but there may be better options for the price. Where are you shopping / located? Budget?
Is 72c at load?
2 minutes ago, Ulol60 said:
I got DDR4 ram only 16 GB tho.
Model name? Depending on profile, it can limit the coolers that fit.
Reseat means to remove and reinstall the cooler. If the issue was a bad mount, a proper mounting can solve the issue. If the thermal paste isn't fresh, you'll need to replace it with new paste.
Moved to Air Cooling.
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459186
Is 72c at load?
DDR4 HyperX predator 3200MHz ram
Am Norwegian so i use a site called "Komplett" that is kind of like amazon just with electronics or i use "elkjøp/elkjop" that is both a store and a online store.
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459192
Is 72c at load?
What are you looking to improve with a new cooler? Are you aiming to oc?
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459225
Not making the pc shutdown cause of the cpu is overheating.... and not being 74C constant...
74c doing what? Is it at boot? During load? What are load temps?
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459233
Yep, okay. Look that's insane. Here's what you do.
Buy new thermal compound, doesn't matter what kind or how much, take off the cooler, clean off the CPU's heat spreader (the metal piece on the CPU when you take off the cooler) with rubbing alcohol, clean off the bottom of the cooler with rubbing alcohol. Get out your vacuum cleaner or one of those cans of compressed air and suck up or blow out all the dust on the cooler.
Now, put about a pea sized dot of thermal paste on the CPU's heat spreader, and put that cooler back on. Then check the thermals. It should drop by about 30 degrees.
When i play games its around 74C like everything from csgo-MW  when i just idle its like 65. Idk what load temps are?
Okay, 74C is load temps. That's normal. 65 C is not normal for idle. Something's going wrong here. It's technically possible your case has tremendously bad airflow, but I think it's just a bad seating on the cooler.
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459254
In my Meshify C I can fit my True Spirit 140 Power, and Le Grand Macho RT no problem. You can move an impressive amount of air with that case. My gpu loads at 58-60 in firestrike extreme.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459258
Now, put about a pea sized dot of thermal paste on the CPU's heat spreader, and put that cooler back on. Then check the thermals. It should drop by about 40 degrees.
Okay i will test it tomorrow.
https://linustechtips.com/topic/1175112-cpu-cooler/#findComment-13459261
