I replaced my stock cooler with an aio recently. I'm doing a test boot to make sure everything is running and I've encountered a no post.
So far I've:
Made sure All power is connected
Reseated my gpu
Rebooting
should I check my cpu to see if it's not seated correctly ? would that change anything ?
https://linustechtips.com/topic/1174375-no-post/
Have you put enough mounting pressure on the AIO's block so the CPU can make proper contact with the socket?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1174375-no-post/#findComment-13453364
8 minutes ago, Hypa said:
I've done the nuts to finger tight I didnt want to put too much pressure on it
Do you have a fan in the CPU fan header? if not that's probably why... either place a fan in the cpu fan header, or go into bios (if you can) and disable the option for it to check that fan header (if you can, as some motherboards don't have this option).
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1174375-no-post/#findComment-13453400
I'm litterally getting nothing to the screen I'm gonna try reseating my cpu next and see if that changes anything
also really weirdly my mouse Is no longer lighting up even tho its connected
https://linustechtips.com/topic/1174375-no-post/#findComment-13453416
