500 is quite the budget, what are you putting in it
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13448515
2 minutes ago, yaboistar said:
360mm AIO's are good for really high TDP chips like threadripper but there's really not much point for chips like these (and the threadripper AIO's are all shit because they gunk up real fast and destroy themselves LMAO) - the large radiators just tend to get in the way a bit.
i personally have an 8700k and i notice practically no difference when running it on my 360mm AIO or my 240. when the 360 finally gets to the end of it's life i'll just switch to a 240.
you could look into a 280MM AIO if you want but at that point top-mounting it becomes a memory clearance issue for a lot of cases, which is another reason why i put it down as 240 because you don't know what case you're getting just yet. Ultimately it's a soldered IHS and I have a H100x keeping the raging inferno that is 8th Gen intel cool at 5.1G in another system.
NZXT tends to make quite overpriced coolers (albeit they're pretty) but even on an open budget, it's not really worth the extra money. It's just an asetek cooler with a different top on it at the end of the day. I'd say to add some more storage drives with the savings on it.
remember - whatever AIO you get, you're gonna want to put some proper fans on it. EK Vardars are pretty good and i use those on all my radiators.
Well that's helpful, Thank you!
I think Im going with H500M case so any AIO would fit without problems.
if you had this budget, what will be your choices? would like to see your build.
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13448859
Actually Hardcore overclocking recommends getting an x570 taichi over the msi ace unless you physically can't look at the asrock bios
Also if your budget is almost 7 grand why not get into the world of custom water cooling
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13448984
Lol i'm planning my first build with custom loop cause I have nothing to do and lots of time and as for best 2080 ti it depends. You could get a kingpin thats worse than a pny blower card because of silicone lottery. Because of this just get a card that has good cooling and that you think looks cool. Most cards custom pcb or not suffer from Nvidia's power limit which restricts your power limit which means it ain't going to matter if their an extra power delivery on the card because of silicone lottery so let me eliterate get a card that looks cool and has good cooling and pray that you get lucky. The exception to this is the hall of fame cards and the King pin that have no such restriction but they are really made for LN 2 overclocking and unless you're comfortable that the Kingpin can draw some 500 whats on an overclock you should buy some different GPU.
AMD blackout rig
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449100
give me your opnion about this:
I'm actually confused between Asus & msi & FTW3 ultra hybird 2080ti's, which one got the best performance??
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449115
First are you gonna just game for however long this pc build will last you? Cause otherwise let me introduce to ryzen
About the graphics card the hybrid has the best cooling so best overclocks = best gpu if you don't mind adding an extra source of failure to your system
AMD blackout rig
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449118
Why do you need so much storage?
Also any sorta budget or are you willing to spend any amount of money?
AMD blackout rig
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449126
Any overclocking?
Quick notice I google searched how much ram you need for 8k footage and it says 64 so that might need an upgrade
AMD blackout rig
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449143
I mean overall if this is what you wan't upgrade the ram to 64 for video editing 8k and that monitor is a no no from me since when video editing you're looking for color accuracy and a VA panel won't give you that that's what an ips is for. But really this is your money if you wan't double kingpin in sli, if you wan't to stick a threadripper in there go for it thats the beauty of building your own pc you can do whatever you wan't but do your research
AMD blackout rig
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449180
42 minutes ago, Kretoo said:
If you have enough moeny to afford that then this probably wont matter but you would shave over $1000 off that with a different monitor/ dual or triple monitor setup instead and going with cheaper other parts but that wasnt the question... Corsair do some good cases, here are some:
https://www.amazon.co.uk/Corsair-Crystal-Airflow-Tempered-Gaming/dp/B07MFR1VDN/ref=sr_1_6?dchild=1&keywords=corsair+case&qid=1586171297&sr=8-6
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449232
27 minutes ago, Gundar said:
Any overclocking?
Yup I'm gonna be overclocking the CPU & GPU if needed for more FPS on that 200hz 2K ultrawide monitor.
No, actually 32GB is overkill, because it's 8K photos not videos.
The videos I'm editing are mostly 1080p.
Yup sure, I'm going to use the LG 27UK-650-W for Editing. it's(4K,27",ips)
I heard that SLI is mostly dead, so getting a single powerful GPU would be the best, but here's the question, again, what's the best 2080ti GPU I can get?
I chose the EVGA GeForce RTX 2080 Ti 11 GB FTW3 ULTRA HYBRID, and im actually confused between this GPU and other popular choices such as Asus & Zotac & MSI.
thanks in advance.
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449234
Cool, how about the GPU?
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449237
Best performance would be the evga hybrid otherwise looks fine to me good luck building
AMD blackout rig
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449241
the MSI Gaming X Trio looks like the fastest out of the box but the EVGA FTW3 ultra hybrid is also great. They all have very similar performance and would only have 1-5fps difference in game so I would worry too much.
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449276
Great, which one is better for an open budget, FTW3 or MSI?
https://linustechtips.com/topic/1173770-high-airflow-case/#findComment-13449278
