@AcerDark How do u know its stuck running at 800Mhz?
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 990 Evo Plus NVME PCI-E 2TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Printers Include -Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer BE9300 Triband Cable Router Wifi6 with a Virgin Media Hub 5.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S25+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/19284824949
https://linustechtips.com/topic/1173363-cpu-stuck-at-800mhz/#findComment-13445077
Are u sure ur checking the CPU and not the RAM?
Internet Speed.....
https://linustechtips.com/topic/1173363-cpu-stuck-at-800mhz/#findComment-13455671
Check in your Windows power plan that Maximum Processor State isn't below 100%.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1173363-cpu-stuck-at-800mhz/#findComment-13455720
On 4/5/2020 at 8:32 AM, AcerDark said:
I started world of Warcraft Warth of the lich king everything at max and opened cpuz and core speed is 800 mhz
Then it's almost definitely thermal throttling. When a CPU gets too hot, it drops down to 800MHz and stays there until it cools down enough.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/1173363-cpu-stuck-at-800mhz/#findComment-13455734
@AcerDark Have u tried resetting and updating the system BIOS?
Internet Speed.....
https://linustechtips.com/topic/1173363-cpu-stuck-at-800mhz/#findComment-13471255
  • 2 years later...
On 4/5/2020 at 4:05 AM, AcerDark said:
So i have Intel Pentium M 760 2GHz that's running on 800mhz I don't know why can some one help me.pls
I just got a ryzen 5600, b450 board on bios f60, that combo ran fine with single channel ram. then i got dual channel and for some strange reason I too am stuck at 800 mhz
https://linustechtips.com/topic/1173363-cpu-stuck-at-800mhz/#findComment-15566967
