Yesterday my PC turned off, completely and wouldn’t turn back on. My router which was plugged into the same power socket also restarted.
It will not post either way, but it wont even turn on if the left 4pin is plugged in but if only the right 4pin then it will turn on however, no display output.
There was smoke coming from the GPU when I first plugged the 4 pins back in.
I’ve reseated RAM + GPU
specs:
i7-4790k
GTX 980 ti Waterforce Xtreme GAMING
240 GB sandisk SSD
750W corsair bronze PSU
16GB corsair vengence pro RAM
https://linustechtips.com/topic/1172600-smoking-gpu/
Sarcastic me would cringe and say Y U LET THE SMOKE OUT BRO
Non-sarcastic me would say something if not all of it is fried. I would recommend taking the system into your local PC parts and service center and have them bench test the components (all of them) and see if everything is okay/damaged whatever the case may be.
F.
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1172600-smoking-gpu/#findComment-13439050
yep, smoke means something burned/popped. take the GPU out and look in the PCB. maybe you can see a component that is black or burned.
https://linustechtips.com/topic/1172600-smoking-gpu/#findComment-13439058
When the magic smoke is let out of the box it will no longer work as intended.  If GPU was smoking then RIP
Can you use the other socket for CPU power delivery?  You could try but personally I would investigate the WHY before possibly frying more hardware
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1172600-smoking-gpu/#findComment-13439082
Throw the GPU out.
Buy a new one.
Problem solved.
/s
Now seriously, if you have a component in your PC smoking it's not a good idea to keep it in there. Toss it in the trash and get a new video card. Repairing them isn't easy and a repair shop is gonna charge enough that it's not worth it on a 980ti.
https://linustechtips.com/topic/1172600-smoking-gpu/#findComment-13439501
