I have a big 90cm by 40cm terrarium and i want to make it nice for my reptile like attaching plants branches etc. I want to be able to make it as a realistic render and as a sketch with measurements etc not necessarily with the same programm with that should i tru
https://linustechtips.com/topic/1171827-programm-for-enclosure-designing/
1 minute ago, straight_stewie said:
How realistic of a render?
How accurate of measurements?
Enough to get my point across to the reptile store staff and enough to order the correct size products based on the size. But I want it to be easy to make it.
Blender is going to be the best option for a realistic rendering, and will probably suffice for your measurement needs as well since you don't need things to be perfectly mapped to the real world.
Blender doesn't work in engineering units though, just in arbitrary units. You can easily just say that the unit length (length "1") has some real world meaning, like 1 centimeter, though, and get close enough estimates of size from that.
ENCRYPTION IS NOT A CRIME
