Okay so when I'm playing fortnite I'll usually get 130-160 fps constantly but I randomly drop to 5-60 fps out of no where.It will only last a second but it is very annoying. It happens at least twice a game for no reason. I think it's something to do with my CPU always being at 100 percent and my GPU at 30 percent. I want to lower my CPU usage and make my GPU usage higher because I think that will fix it. I'm playing on all low setting and the resolution is 2560x1440.
PC part list
i5-9400f
B360M-MOTHERBOARD
GTX1660 zotac 6gb
8drr4-2400mhz
https://linustechtips.com/topic/1171548-i-need-help/
Might sound counter intuitive, but see what happens if you crank your settings up a bit from low.  This will get more utilization out of your GPU and might give your CPU a break.  You are describing a classic bottle neck scenario.
The big drop in performance is could be your CPU thermal throttling, trying to keep up with your GPU.  How are you cooling your CPU?  What are you CPU temps?
https://linustechtips.com/topic/1171548-i-need-help/#findComment-13430473
if thats 1 stick of ram, it'll do that
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1171548-i-need-help/#findComment-13430498
