I have 8700k RockItCool copper ihs, conductonaut, 5.5GHz 4 core 5.4GHz 2 core, NHD-15, MSI SLI Plus, 4x4 4000MHz Vengeance LPX, 970 Evo 500Gb, 3TB Barricuda. I want to play destiny 2 1440p pvp at 144-165fps. Should I wait till September? I can't buy a 2080ti. I used to play with 2 1070's back when it was on blizzard and was around 130 :) I have everything off or lowest except highest textures highest character textures 16x anisotropic.
I trip to make the fall shorter
https://linustechtips.com/topic/1171452-what-gpu-for-my-build/
best for the value would be a 5700 or 5700XT unless you can find a used 1070ti, 1080 or 1080ti
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1171452-what-gpu-for-my-build/#findComment-13429515
What GPU do you have now? Budget?
though the entire build is on the disappointing side when you have a top bin 8700k like that
Desktop benching:
https://linustechtips.com/topic/1171452-what-gpu-for-my-build/#findComment-13429541
I would get a 2080 super, unless you’re willing to wait until the new launch. If you’re willing to go on the used market, I would get a 1080ti.
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1171452-what-gpu-for-my-build/#findComment-13429547
