I am building my first pc and am looking for some advice on what components I should pick.
Budget- prefer $800-950, could stretch to $1000
Location- US
Use- Mostly Gaming  (SOTR, COD MW, Forza Horizon 4, Anno 1800) and some light productivity
Peripherals- 1 1440p 120 Hz monitor, prefer gaming at higher res, lower fps
Research so Far- Ryzen 5 3600 and an EVGA RTX 2060 KO but i am concerned if this graphics card would run pretty loud and would appreciate anyone relating their  experience with this card.
Open to suggestions on all components, with my preference on getting a not very fancy case without a glass side panel.
https://linustechtips.com/topic/1171113-first-pc-build/
Considering you're playing at 1440p, better idea to get an R5 2600 and upgrade the GPU instead.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($119.99 @ Newegg)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($84.99 @ Newegg)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory  ($67.99 @ Newegg)
Storage: HP EX900 500 GB M.2-2280 NVME Solid State Drive  ($61.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.98 @ Newegg)
Video Card: MSI Radeon RX 5700 XT 8 GB EVOKE OC Video Card  ($367.99 @ B&H)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: be quiet! Pure Power 11 CM 500 W 80+ Gold Certified Semi-modular ATX Power Supply  ($79.90 @ B&H)
Case Fan: Rosewill RAWP-141411 82 CFM 140 mm Fan  ($13.99 @ Newegg)
Total: $911.81
Generated by PCPartPicker 2020-03-31 02:06 EDT-0400
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1171113-first-pc-build/#findComment-13426113
Total: $911.81
you'd be better off with a 1600AF for 40$ less if you going 2nd gen ryzen.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1171113-first-pc-build/#findComment-13426125
The 1600AF is out of stock across the US, at least from what I can tell. Amazon, Newegg, etc.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1171113-first-pc-build/#findComment-13426128
dam it was just in stock last night. I'd guess amazons hold on new stock is stopping it.
https://linustechtips.com/topic/1171113-first-pc-build/#findComment-13426136
