Hello
at this point I don't know where else to turn. So basically I have an old computer we are talking I7 4790, ASrock Z97 killer motherboard, and GTX 760 GPU and a 600W AEROcool strike x 80 plus bronze PSU. So my GPU started failing around Q4 2019 I baked it so it worked again and worked for over 4 months now but i decided to buy a RTX 2060. for 14 days it ran like a charm then it just stopped working PC doesn't even turn on. I don't know how to describe it but when u press the power button it just stutters a bit, looks like it will turn on for a sec but then dies completely. At this point I tried re-slotting the GPU, reinstalling updates... I am in no position to really throw money away but I need this GPU to work because i'm a student. I am suspecting the old PSU but i'm not sure and I am not willing to throw out 150€ to find out. Would really appreciate any help, tips how to test it, literally anything.
Thanks in advance.
https://linustechtips.com/topic/1170832-rtx-2060-problems/
sounds like the PSU
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423642
10 minutes ago, Schlegell said:
Hello
Thanks in advance.
Sounds to me like a faulty PSU. If the PC will not even turn on, it is unlikely the GPU is at fault. If the GPU was faulty, you would at least get the PC to boot, and you could try to plug the monitor into the onboard video.
Especially because you upgraded to a more powerful GPU, likely the PSU cannot supply stable power.
A decent quality PSU can be bought for around 50 EUR, so no reason not to try and fix it. Buy it from a place where you can return it if that turns out not to be the fix.
Something like this: https://de.pcpartpicker.com/product/kCtQzy/evga-br-500w-80-bronze-certified-atx-power-supply-100-br-0500-k1
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423665
takle the card out and run the iGPU, does that work?
Desktop benching:
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423667
A decent quality PSU can be bought for around 50 EUR, so no reason not to try and fix it. Something like this: https://de.pcpartpicker.com/product/kCtQzy/evga-br-500w-80-bronze-certified-atx-power-supply-100-br-0500-k1
The PC turns on just okay if i leave the GPU in the PCIe slot and just disconnect the 8 pin from the GPU, and also if I run it from the onboard HDMI turns on just fine aswell, so it's safe to say it's the PSU?
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423681
Could be PSU killing the card, could be just bad luck with cards. Good PSU wont cost nearly as much as a card though so I'd still replace the PSU
Desktop benching:
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423684
3 minutes ago, Schlegell said:
Probably going to buy a PSU now and if it doesn't work i'll just put the GPU in the oven. Thanks a lot guys.
NO, don't put a new GPU in the oven, it'll get worse before it gets better.
EDIT: And 650W PSU should be enough?
A 450 watt PSU will be enough. Get a high quality PSU, around 450 to 550 watts.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423709
Im looking at a Cooler master MWE BRONZE 550W 80+ ?
The MWE V2 is worth considering, but not the V1.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423729
Buy a good power supply so you don’t have to worry about stuff like this. Don’t cheap out on it and buy a quality unit from the tier list.
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423783
Yes, sounds like the PSU for sure. Faulty GPU's rarely cause a system not to boot at all, they will just not show an image, but the PC should boot.
DONT put a GPU in the oven. I am not sure where this idea took hold, probably a dumb LTT video. If the card is super old, and it is 100 % not working anymore, AND you are not using the same oven to cook food, sure, go for it.
But WHY would you do that to a GPU that is probably still under warranty?? Just return it to the manufacturer for a replacement!
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423791
Thanks, note taken.
I did it with the GTX 760 and it worked, that's why I considered it. About the manufacturer in my country you can't really do that in my knowledge. And don't really know how to return a card to ZOTAC if it's faulty
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13423868
On 3/30/2020 at 6:39 PM, Schlegell said:
Thanks, note taken.
Just look on Zotac's website: they have support websites for most European countries (I assume you are in Europe given the price in euros):
For example German website:
https://www.zotac.com/de/support#contact
You just send them a support request through their website, and I am sure they will ask you to send the GPU back to them for a repair or replacement. Most electronics companies have a system like this nowadays (and you shouldnt buy from a manufacturer who doesn't).
Standard warranty by law for all electronics in Europe is 2 years. Since it is a 2060, I assume it was bought less than 2 years ago. Not offering warranty replacement would be illegal within the EU.
https://linustechtips.com/topic/1170832-rtx-2060-problems/#findComment-13438055
