It's quite a good list, but you can afford a 1660 super for the price of that 5500 XT. For reference, the 5500 XT performs roughly equally to the 1650 super, which sells for about $160
https://pcpartpicker.com/product/ByqBD3/evga-geforce-gtx-1660-super-6-gb-black-gaming-video-card-06g-p4-1061-kr
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421354
Your saying that the 1660 super is eqaul to the 5600xt?
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421363
Overall very good.
You can get the memory a bit cheaper from here: https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232882
the MSI A-PRO Max is IMO better looking (especially if you're going for a color-neutral build, is $5 cheaper, and has the same VRM.
Good PSU choice, but you could save like $20 by going for something like a corsair CXM -- not necessarily a better option, just something to think about.
GPU is really the big one here. You should totally get a 1660 Super if you can. Maybe with some saving and/or stretching your budget, you could fit in a 2060 Super, but that really might be a stretch.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421367
The 5600 XT is closer to the 2060
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421369
3 minutes ago, TheRedBarron said:
5700xt!
The 5700 XT is very close to the 2070 super
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421384
1 minute ago, TheRedBarron said:
Is there anywhere where I could save money? Im on a tight budget.
29 minutes ago, RadiatingLight said:
Overall very good.
Laptop:
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421432
Thanks
Check out something like this:
Non-modular PSU but that should be okay since your case has a PSU shroud.
Laptop:
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421464
Its a 5700xt sorry its 3am.
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421475
Can you think of another way to say money or any improvements. Thanks this stuff is really expensive in Europe.
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421537
Your original selection of the 5500 XT should just be replaced by a 1650 super, if that is available to you. What part of Europe?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421569
No sorry I meant to put the 5700XT not the 5500. Im just very tired.
I understand now.
In that case, the only reasonable performance alternative is the 2070 super, but that's usually more expensive. Your parts list looks quite good.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13421592
What country?
I've been optimizing with US PC partpicker, but you can change PC partpicker regions and see which parts are cheapest for you locally
Laptop:
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13422116
What part of Europe? We can tailor lists to specific countries.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1170557-pc-part-help/#findComment-13422313
