Hi guys im new to this one so can you guys help me build a pc my budget is $1,600 and im going to use that pc for gaming and streaming.
Im having a hard time what brand to buy and i dont know if i need the "extra features", I mean i know what to do but what do i buy there are tons out there i need that $1,600 to be worth it.
Thank you in advance
https://linustechtips.com/topic/1170546-help-me-create-a-pc-2020/
I'm not sure what "extra features" could mean but I'll certainly give you bang for buck
Primary PC:
PSU tier list
How many watts do I need?
You can afford a pretty fancy GPU model, and a nice power supply as well, with a budget like that. Put it all inside a good NZXT case and you're all good to go.
PCPartPicker Part List: https://pcpartpicker.com/list/fFqKk6
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($298.99 @ Newegg)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($104.99 @ B&H)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ B&H)
Video Card: MSI GeForce RTX 2080 SUPER 8 GB SEA HAWK X Video Card  ($714.99 @ Newegg)
Case: NZXT H510 ATX Mid Tower Case  ($69.99 @ Best Buy)
Power Supply: Corsair HX Platinum 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($217.98 @ Newegg)
Total: $1586.92
Generated by PCPartPicker 2020-03-29 20:05 EDT-0400
Trash beauty:
CPU: Xeon X5550
GPU: RX 570 4GB (defective)
SSD: Fattydove Racing 240GB
HDD: WD Blue 320GB
Motherboard: HP Z400
Ram: 6x2GB DDR3 1066
PSU: Corsair TX650
This is a step down on the graphics card from other people's entries, but has faster RAM and will be a decent bit quieter. Everything here is a good build though, this is just my take on it.
The CPU and GPU can be purchased used. I'm on my second round of upgrades and the used market hasn't burned me yet. I always buy from Ebay and from sellers with several hundred top reviews.
Motherboard: Asus Tuf X570-Plus | CPU: AMD Ryzen 7 5800x Eight-Core Processor | GPU: Zotac GeForce RTX 3080 10gb  | RAM: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL14 | Case: ATX Mid Tower Case | Storage: Samsung 970 Evo 500GB & 1TB M.2 | Display: Samsung C27HG70 27" 2560x1440 144Hz 1ms | Operating System: Windows 10
With higher end stuff there's very little money to be saved. Better off going new for the warranty.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
This should do pretty good. A beQuiet Dark Rock Pro 4 CPU cooler would fit in the budget if you don't have other things to buy and NEED silence.
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($144.99 @ Newegg)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory  ($67.99 @ Newegg)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  ($673.98 @ Newegg)
Case: Cooler Master MasterBox MB511 RGB ATX Mid Tower Case  ($97.98 @ Newegg)
Power Supply: SeaSonic FOCUS 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($104.99 @ B&H)
Total: $1498.91
Generated by PCPartPicker 2020-03-30 02:48 EDT-0400
Windows can be purchased on ebay for roughly 3USD.
Full Specs
Helios EVO (Main):
Delta - Laptop
