copied my post from reddit.
mainly playing PUBG. Getting anywhere from 144 to 6 FPS. but usually 40-50 fps. does not feel stable but that's what the counter says.
my pc specs: https://support.hp.com/us-en/document/c05536436
Monitor: https://eu.aoc.com/en/monitors/g2460pg/support
System type: Windows x64
BIOS Version/Date: AMI F.27, 24/05/2019
UserBenchmarks: Game 69%, Desk 74%, Work 39%
CPU: Intel Core i5-7400 - 68.9%
GPU: Nvidia GTX 1070 - 74.1%
SSD: Samsung MZ7LN256HMJP-000H1 256GB - 120.4%
HDD: WD Blue 1TB (2012) - 97.8%
RAM: Micron 8ATF1G64AZ-2G3B1 1x8GB - 43.7%
MBD: HP 870-250no
what iv'e tried:
- Turned it off and on :^]
- Updated all drivers :^)
- overclocked GPU.
-"underclocked" GPU
- turning down all settings in pubg.
- messed around with Nvidia control panel settings.
- Tried 750W PSU
- reformatted PC to factory settinngs
i have pictures from CPUID, pictures from Haven benchmark and video where i play a game. but it is alot of pictures so i'll post on request
additional information:
my pc did not display anything on screen, power keyboard or mouse. the way i "fixed" this was by re-seating all cables. draining PSU, then plug only the power cable in again and start wait 5 sec and then plug all cables in again. i came across this setting called fast start up which i disabled and it seems to be working fine now.
thanks in advance for any input on this :D
https://linustechtips.com/topic/1169732-stutters-and-low-fps/
3 minutes ago, lexar512 said:
i have a recording of me with frametime displayed on-screen. but now that im thinking it would probably be better if i had a graph?
🤔 When you say you tinkered with the nvidia control settings, which ones exactly? Have you tried turning on G-Sync or Fast Sync? You might be stuttering because your frame time is out of sync with your monitors refresh rate. You can also try bench marking it to get your average highest frame rate. If 40-50 fps is the most you get, then you might as well lock the target frame rate at that number and call it a day. You might get a more stable performance that way as well.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414382
dropping this graph of frametime here. this is in training, fullscreen, g-sync off, 30 fps cap
Did the stuttering stop? If not, I suggest you try it with G-Sync on. This is assuming you have a G-Sync monitor, at which point you can just use Fast Sync.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414450
when i was playing the game earlier and did a recording. i got roughly 20 ms frametime. but spiked to 100-200 on occasions. now that im in training (smaller map) i get a higher Frametime. but no stuttering is still a problem. the graph does not look steady in my opinion.
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414454
1 minute ago, lexar512 said:
@BlackManINC tried gsync also same story
🤔 Where do you have your games and operating system installed, your HDD or SSD?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414466
SSD. 140 GB left aswell.
Your games and operating system are on the SSD?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414479
Just now, lexar512 said:
I'm assuming your operating system is up to date. I would also suggest updating your bios, but you have an HP computer, and HP is a problem when it comes to this. The last company I'd buy a computer from at all is HP. HP is ass liquid, I had one just last year, and the last time they provided an update for my old computer was seven years ago. You can try and get a bios update from the link. If not, customer service might give you one, the problem is they will likely charge you for the service. If this were me, I'd be looking to replace this computer with another one enteily, because for some reason HP is allowed to sell PC's without updating to the bios.
Link: https://support.hp.com/us-en/drivers/desktops
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414513
4 minutes ago, lexar512 said:
Oh yeah, you should also get another 8 gbs of ram as well, and that CPU usage rate is a bit too high. It shows that your CPU could be bottle necking the performance.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414516
39 minutes ago, lexar512 said:
and i have F.27
No, it looks like F.28 is the latest you can get. I would try getting that one if you can. Yours is from may, F.28 is from june.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1169732-stutters-and-low-fps/#findComment-13414655
