Micro-ATX case
Go to solution Solved by Aniallation,
My vote goes hands down to the 350D. No it does not have bad airflow, in fact it's way better then prodigy/phenom M, most silverstones, etc.
Caselabs S5
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/116973-micro-atx-case/#findComment-1561615
Surprised nobody has said anything. I'd look at the Corsair 350d and the Fractal Design Arc Mini R2
I have been thinking about the 350D but people are saying it has bad airflow, how is it for you? Also, how is the gryphon z87 motherboard, thats the one i plan on getting.
https://linustechtips.com/topic/116973-micro-atx-case/#findComment-1562054
Haha, thats a build I'm looking to buy. I've only heard good things about both though.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
https://linustechtips.com/topic/116973-micro-atx-case/#findComment-1562087
The airflow is fine but it's a large case for matx. What about the gryphon? It's good?
https://linustechtips.com/topic/116973-micro-atx-case/#findComment-1562142
