The resolution and set your max bitrate. I am not sure what else helps I do not understand it all
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/116962-need-obs-tips/#findComment-1561433
For 720p out bitrate to 2200. For 1080p its something like 2700-3300. FPS set to 30, quality 8. You should record max resolution and scale it down to what you like. With bitrate more is better quality but will also need more power from you and better internet from you viewers. So don't overdo it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/116962-need-obs-tips/#findComment-1564661
