Hi guys. I am trying to run Folding@Home but realized I am running into some high temps... I have a Ryzen 2700X and a RTX2070. The CPU has a Corsair H80i v2 and the graphics card is just air cooled. I thought it would be no problem but quickly realized my CPU temps where hitting 86 C at only 40% usage which seems a bit high. There are 2 120mm fans blowing in the front of my case and the Corsair cooler blows out the back. Any ideas what could be wrong? Side note, the plastic part of the cooler where the pipes feed toward the CPU seems to be loose but that might be normal.
Any help is greatly appreciated. Thanks!
https://linustechtips.com/topic/1169504-high-temps-when-using-foldinghome/
folding uses a lot of power to run the simulations.
more power means more heat.
the H80i is also a small aio for the power of the 2700x so temps will be higher
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
Would you recommend upgrading the cooler then? I looked into the temps more when I noticed that and saw they were pretty high in games too. When the usage was under 20%
Look at your fan curves in Corsairs program. I have an H80i and it sets the fan speed for water temp and not CPU temp, so check what your water temps are, you might have a bad mount. I have a similar setup to you except I have an overclocked 7700k, at 100% usage I see CPU temps in the high 60's low 70's with two 120mm Noctua fans going full tilt.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
If you're concerned with the temperatures, you can set a package PPT power limit with Ryzen Master.
Desktop 1 : Ryzen 5 3600 (O/C to 4Ghz all-core) | Gigabyte B450M-DS3H | 24GB DDR4-2400 Crucial(O/C to 2667) | GALAX RTX 2060 6GB | CoolerMaster MWE 650 Gold
Desktop 2 : i5 10400 | 32GB DDR4-3200(@ 2667Mhz) |  EVGA GTX 1070 SC 8 GB | Corsair CV450M
Laptop : ASUS ROG Strix G17 : i7-10750H, 16GB RAM, GTX 1660Ti 6GB(90W), 1TB NVMe SSD
Yoga 3 14 - i7-5500U, 8GB RAM, GeForce GT 940M, 256GB SSD
For whatever reason, the iCUE program usually says 0rpm for my fans even though I can see they are running. Maybe I need to contact Corsair and see what the issue is there. They might not be ramping up when they should. Thanks!
