5 minutes ago, Doc Mitchell said:
Does anyone have a good build that can run all the fallout games at max settings? Mods included. Budget is under $1,000. I do not have a monitor/ keyboard. But I won't count it towards the overall cost. Thanks a million.
Ryzen 5 3600
AMD RX5700XT
16 GB DDR4 3600 mhz RAM
ASRock B450M PRO4 MB
1 TB SSD
Corsair VS500 PSU
That should play just about anything on near max settings at 1440p and be within budget
https://linustechtips.com/topic/1166075-build-ideas/#findComment-13383392
1 minute ago, Doc Mitchell said:
Is it still alright to get the Ryzen cpu along with the Msi 540 motherboard? It's giving me a warning saying it could have a potential issue.
the msi MAX boards come with the correct bios version, so don't worry about the warning.
https://linustechtips.com/topic/1166075-build-ideas/#findComment-13383433
I think the reason is it may not have the newest BIOS version and may need to be updated to work with the R5 3600.
edit: More than likely it does have the updated BIOS version unless it's been sitting on the shelf for the past 9 months....
https://linustechtips.com/topic/1166075-build-ideas/#findComment-13383435
You can turn a 5700 into a 5700xt by flashing a new bios... kinda dumb
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1166075-build-ideas/#findComment-13383454
27 minutes ago, steelo said:
Personally, I wouldn't try it...way too much risk of bricking it
It’s actually not that risky at all. Your just flashing bios so the card thinks it’s a 5700xt, that’s the only difference between the two cards is bios amd locking down clock speeds.
AMD blackout rig
https://linustechtips.com/topic/1166075-build-ideas/#findComment-13383560
