Power supply orientation
Solved by minibois,
Just now, Renn772 said:So I recently bought a Coolermaster Masterbox MB530P, The power supply can go both ways. I was just wondering if one way is better then the other
Only point is up if your case is sat on carpet, where it will be that the power supply can't breath in air.
In all other scenarios you'll want the fan-side down (as it takes in air that way). If you do end up putting it on carpet, you can always get a piece of wood to stand it up on.
