4 minutes ago, Roppa the Blyth No1 tattoo said:
Why does the xbox360 controller I have just gotten have a round connector instead of a USB type??? And, what can I do to resolve the issue?
It almost sounds as if you are describing the cable on an original Xbox controller.
The Xbox 360 controllers were either wireless or USB.
19 minutes ago, Roppa the Blyth No1 tattoo said:
Thanks for the informative reply, however, the cable is hard wired into the controller and the controller has "XBOX360" on the front! 🤷‍♂️
Can you please share a picture of this controller and its cable?
Currently uploading pictures to this forum doesn't work, so you can use something like imgur.com to link a picture
It's probably a 3rd party controller with a breakaway cable on it, the guitar hero guitars for the 360 also had as do some of the newer 3rd Part Xbone controllers, you can buy the female end of the breakaway (the part with the USB plug on it) on Ebay typically or buy a cheap 3rd part like Rock Candy controller and use the other end from it if you don't mind that they may not match.
They have those so if someone were to like walk by your console or something instead of yanking the console off the where ever it is, the cable breaksaway.
Edit: Link to breakaway cable:
https://www.ebay.com/itm/USB-Breakaway-Cable-Cord-Adapter-For-Xbox-360-PC-Wired-Controller/302434275870?hash=item466a7cd21e:g:rEgAAOSwtz5dH-oM
#AllBirbsAreEqual
My Humble Budget Build
  • CPU
    Ryzen 5 2600
  • Motherboard
    ASUS B450M
  • RAM
    T-Force 16GB 3000mhz DDR4
  • GPU
    Powercolor Red Dragon Rx580 4GB
  • Case
    Rosewill ATX Mid-Tower
  • Storage
    1 X WD 1TB HDD
    1 X Seagate 2TB HDD
    1 Silicon Power 256gb SSD
  • PSU
    EVGA850 BQ
  • Display(s)
    HP 1920 X 1080 Monitor
    Acer SB220Q bi 21.5 inches Full HD
    Acer 1440 X 900 Monitor
  • Cooling
    Enermax Liqmax III
    1 120mm Rosewill Case fan
  • Keyboard
    Corsair K68 RGB Keyboard
  • Mouse
    Razer Naga Trinity
  • Sound
    Insignia Computer Speakers
  • Operating System
    Windows 10 Ultimate
