Hello, I was wondering is it worth it to liquid cool a Gigabyte Aorus Master X570 board with a monoblock (cpu+vrm) and a chipset waterblock or should i just cool the cpu? I know the Aorus master x570 has a heatpipe for its vrm and large heatsinks so i'm not sure if its needed or if it would be any good for looks.
Thanks in advanced
https://linustechtips.com/topic/1165198-chipsetvrm-cooling/
No need for chipset unless you have a 3 slot card kicking out 300w of heat. You could check chipset temperature if you're worried, even 70C is fine for it
No need for VRM, only use it for looks which is in the "want" category
Desktop benching:
https://linustechtips.com/topic/1165198-chipsetvrm-cooling/#findComment-13375812
Ok, my chipset is around 50C with graphics cards under 100% load.
This is the product picture of the monoblock what are your thoughts on the looks?
https://linustechtips.com/topic/1165198-chipsetvrm-cooling/#findComment-13376941
look ok, not a fan of watercooling myself
Desktop benching:
https://linustechtips.com/topic/1165198-chipsetvrm-cooling/#findComment-13377576
I check the block manufactures then get a board they have stuff for. Normally ASUS for me. Get ram blocks while you are at it.
https://linustechtips.com/topic/1165198-chipsetvrm-cooling/#findComment-13379548
7 minutes ago, DominicNikon said:
Wouldn't ram blocks make it look too crowded with the extra tubing involved?
Depends on how dedicated you are. Some of the best looking builds pull it off.
My spare rig is kinda crowded but I like it that way. Seems worth while.
https://linustechtips.com/topic/1165198-chipsetvrm-cooling/#findComment-13379797
