- Not including Monitor, Mouse and Keyboard. -
Im building a budget Gaming Rig Centered around a Ryzen 5 2600, don't have a clear picture of some parts though so i was hoping for some help figuring out what to get and opinions on what im getting for now, (Trying to stay around or under £600, if thats not possible please indulge me to a more reasonable price range, im not really an expert at this). Not planning to play triple A titles with Ultra graphics by any means, just enough to get a good experience.
Current Plans:
  • Cpu: Amd Ryzen 5 2600 - £110 (Cooler Included)
  • Motherboard: Asus Prime B450M-A - £70
  • Chassis: Metallicgear 520 Series Neo Air (with an Added fan) - £64
  • Ram: G.Skills Ripjaws (16Gb) £81
  • Psu: Undecided
  • Gpu: Undecided, but my guts tell me an Rx580 is the right choice.
  • Ssd/Hdd: Undecided (Ssd or Hdd??)
https://linustechtips.com/topic/1165026-ryzen-build-help/
Current Plans:
  • Psu: Undecided
Here's my take based on what you posted:
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
https://linustechtips.com/topic/1165026-ryzen-build-help/#findComment-13374051
A little over £600, but the 1660S offers a pretty significant boost in performance over the RX 580. If you can't go over, then the 580 would still be a great choice, or you could go for a 1650 Super which is about on par with the 580 in terms of raw performance, but consumes about half the power.
Speaking of power, if you want a modular PSU, a TX550M would be a great choice, and it's also not much more expensive than the CX550. Additionally it brings higher quality components along with higher efficiency.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1165026-ryzen-build-help/#findComment-13374116
PCPartPicker Part List
CPU: AMD Ryzen 5 1600 (14nm) 3.2 GHz 6-Core Processor  (£88.97 @ CCL Computers)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  (£82.99 @ Amazon UK)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3000 Memory  (£68.26 @ Amazon UK)
Storage: Western Digital Blue 500 GB 2.5" Solid State Drive  (£60.75 @ CCL Computers)
Video Card: Gigabyte GeForce GTX 1660 SUPER 6 GB OC Video Card  (£209.99 @ Amazon UK)
Case: KOLINK STRONGHOLD ATX Mid Tower Case  (£38.99 @ Currys PC World)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£69.98 @ CCL Computers)
Total: £619.93
Generated by PCPartPicker 2020-03-15 16:37 GMT+0000
https://linustechtips.com/topic/1165026-ryzen-build-help/#findComment-13374167
