Hey Guys,
So, with my income tax return i was able to purchase a PC upgrade to a Ryzen 7 3800x. Currently, i have a Corsair H80i v2 AIO attached to it. Stress testing showed my temp couldn't get over 81 degrees. (As they are rated for 100 degrees, 20 degree wiggle room seems fine)
The Radiator has 2 fans in a push/pull configuration, and has a lot of airflow through the 120mm radiator.
My question is, should i just keep this AIO, or would it be better to upgrade to a 240mm rad with 2 fans in a push configuration? Such as the Corsair H100i?
The rad would have more surface area, but the airflow would be stepped down without the push/pull configuration.
Thoughts on this?
https://linustechtips.com/topic/1164586-cpu-aio-cooler-question/
Personally, I prefer a 240mm rad, mainly because you'll get better cooling even with just push or pull, instead of both, and can cool at a much lower fan speed, so less noise.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Sounds like you don't need to do anything if you're happy at 81 degrees and its inside the safe rating. So the only thing to worry about is board flex.
What case is this fitted inside? I'm guessing this is a push pull exhaust rather than push pull intake?
I'm an IT System Admin with 15+ years worth of XP, plus I've been tinkering computers since I was old enough to hold a screwdriver, so I usually know what I'm talking about.
The case layout is as follows:
200mm intake fan located on the bottom front of the case
200mm exhaust fan on the top of the case
120mm exhaust AIO near the top of the case, close to the 200mm exhaust.
If i go with the 240mm Radiator, it would take the place of the 200mm exhaust on the top of the case, and i would add a 120mm intake fan to provide some cool air feed closer to the Radiator.
https://www.coolermaster.com/catalog/legacy-products/cases/enforcer/
2 minutes ago, Phil Cunningham said:
I guess what my real question is, would i see enough of a loss in temps to warrant the purchase of a 150$ AIO. If i am only expected to see a 2 or 3 degree change, then its not worth it.
What are your ambient temps?  While I know the chiplet design of Zen++ can get pretty hot, my 120mm AIO on my R7 1700 only gets to 56c max during heavy loaded sessions in push/pull.
I think you would see a 5-10c drop going to 240mm radiator.  I think with the right TIM (TG Kryo) you would see an additional 3-5c drop.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I don't have an exact number for ambient temps, i usually keep the room cool, and there is an AC unit right above the tower. So ambient temps are never very high. The AIO is about 3 years old so a new one wouldn't be a bad idea. I suppose i am just on the fence. (I mean lets face it, who wants to spend 150-200 bucks if they don't NEED to, right? lol) But its always amazing to hear other peoples opinions on the subject. ?
