Hard to say without any physical information about the actual system.
What specs?  What are temps?
https://linustechtips.com/topic/1164378-more-fans/#findComment-13369099
2 minutes ago, guttmannen said:
temps is good cpu 60 and gpu 80 while playing harder games. i got a ryzen 3400g and a gtx 1650
Sounds fine to me.
By the way just make sure to quote when you respond
https://linustechtips.com/topic/1164378-more-fans/#findComment-13369116
i would put a fan in every spot, more intake than exhaust for a positive pressure!!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1164378-more-fans/#findComment-13370414
Picture of case (both inside and outside) or model name will be needed if you want to know more about airflow options etc.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1164378-more-fans/#findComment-13370541
