120x38, pick the right one and it will blow every other fan that people will recommend away. I like Panaflos, but there are others.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1163961-best-case-fans/#findComment-13365426
Just now, CreativeName642 said:
I know that 140mm will get better airflow, but IDK about sound. Either is fine.
Corsair ML120s come in a 2-pack for $35 on Amazon right now. The ML is my favorite fan design right now in terms of noise to power. Noctua's Redux fans are also up near the top, and a 140mm 1500RPM PWM fan will set you back $15 or so.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1163961-best-case-fans/#findComment-13365439
  • 2 weeks later...
System specs? Where are you shopping / located?
https://linustechtips.com/topic/1163961-best-case-fans/#findComment-13387817
ML120s get considerably noisy at higher RPMs.
On 3/11/2020 at 1:14 PM, CreativeName642 said:
I need the best case fans for static pressure. I'd like them to be a balance of quiet and powerful. My price point is ~15-$20. My case is the Corsair Carbide 175R
NF-F12s or Redux fans are a good choice. Be Quiet! Pure Wings 2 are also nice at a lower price point.
As a wise master once said,
Put as much effort into your question as you would expect a stranger to add to their answer!
Desktop: AMD Ryzen 5 3800XT | Gigabyte X570 Aorus Ultra | Corsair Vengeance LPX 32 GB 4000Mhz CL18 | MSI RX 5700 XT Gaming X | Two WD Black SN750 1TB NVMe SSD | Corsair AX850 Titanium | Fractal Design Define 7 White, Solid
Laptop: Apple Macbook Pro 16 | i9 9980H | 16 GB RAM |  1TB SSD | AppleCare+ | Space Grey
Peripherals: RAMA U-80 Lake | Logitech MX Master 3 | Kanto YU2 White + Beyerdynamic DT 177X GO
Displays: LG GX 55"| Acer XB273K | Dell Ultrasharp U2720Q | LG 32UN650-W
https://linustechtips.com/topic/1163961-best-case-fans/#findComment-13389052
