Hi everyone,
I'm on my last legs with what is wrong with my pc.
I have an intel core i5 7600, 16gb ram and a Nvidia 1070 graphics card.
I used to able to record/stream games quite well but now even when my computer is not doing much my cpu can get up to 100% usage...
This makes it difficult for me to stream which I know is intense on the cpu but as I said was initially fine. I am avoiding overclocking because that is not what I am comfortable with as I am not that skilled, I have only built this pc which I have had for a few years now.
Friends seem to think my processor is just old and is bottlenecking, others think my gpu might be faulty making my cpu work harder than normal. Thermals could be better but they never run too hot.
Im just stumped with what I can do without having to take it all apart, I'm looking at upgrading my processor to an item core i7 9700 or 9700K (whatever I can afford) if needed.
I would love some advice if that is possible?
Thanks,
Connor
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/
Your cpu just isn't strong enough to efficiently process that workload
If you wanted to upgrade, look at ryzen and grab something like a 2700 or 3600
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359484
What is using the CPU so much anyways?
You would need a new motherboard for that. 7700(K) is the best you can do on your current motherboard.
If you're getting a new motherboard, you might also want to look at Ryzen, since them having more cores is a lot more preferable for streaming.
Or look into encoding on your videocard, might work well too.
Speaking of encoding.. Is it possible your streaming program's settings have simply just changed?
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359488
23 minutes ago, JustConnor said:
Hi everyone,
Thanks,
Connor
The 7600 isn't enough anymore. 4 cores, 4 threads are essentially on the lowest-end for performance. Even 1st generation Ryzen CPUs handily slap around the chips they first compete with. You need more CPU horsepower to do anything else.
If it comes down to upgrading your CPU, unless you can get the 7700K for dirt cheap (AMD has devalued all Intel processors on a massive scale), I'd just go AMD as a whole. Heck, I used Intel for the longest time because AMD could not compete. Now they can, and are handily smacking Intel their collective butts.
S.K.Y.N.E.T. v4.3
AMD Ryzen 7 5800X3D | 64GB DDR4 3200 | 12GB RX 6700XT |   Twin 24" Pixio PX248 Prime 1080p 144Hz Displays | 256GB Sabrent NVMe (OS) | 500GB Samsung 840 Pro #1 | 500GB Samsung 840 Pro #2 | 2TB Samsung 860 Evo1TB Western Digital NVMe | 2TB Sabrent NVMe | Intel Wireless-AC 9260
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359524
Only issue is I don't want to switch to an AMD build... is there any suggestion on an intel processor I can upgrade to?
my software settings did change but I reverted them back but even then it still doesn't perform well, even using a dynamic bitrate
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359587
New intel drops next month (april) or may. So if you're sticking with intel just wait a little longer.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359600
Thanks man! if I am to upgrade to an i7 would you suggest yours for my build? my graphics card is a 1070 but only 3gb but I know it can handle it quite well
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359606
If you're not changing the motherboard, than it's the best you're going to get. If it's not to pricey. 7700K is a great CPU though in my opinion. I stream as well and do so at 1080p60fps no issues or frame drops.
If you can wait and get new Mobo and new intel CPUs I say do that. However new intel may become "supply & demand" prices.
Your talking about a 1060 not 1070 right?
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359647
No, I don't think Intel makes sense for this purpose, except for the 9900K, or maybe 8700(K), which are both just very expensive, where AMD makes more sense for your use.
But you can do your own research whether Intel makes sense for you.
You could try the NVENC encoder, which runs on your videocard.
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359712
Yes, NVENC(new) is what I use and is best. Instead of going through 3 different pieces of hardware.
https://linustechtips.com/topic/1163310-cpu-100-not-sure-why/#findComment-13359906
