Help regarding airflow
Solved by Audherbagn,
Ok so currently you have everything backwards. The top and front fans are acting as exhaust and the one back is acting as intake. This is not a good idea. When you have that much negative pressure and no filter on the intake you end up with loads of dust in your case. I would flip the two rad fans to intake, and the back fan to exhaust, then run the 3 exhaust at lower rpm than the intake so you still have balanced airflow, dust filters, and aesthetic.
