Quiet, High Airflow, 92mm Fan
flibberdipper
The rear fan in my grandma's HP is loud, and I want to replace it with the best airflow/noise ratio. Keep in mind, it'll be spinning anywhere from 25% to 50% of the full speed, and it has to be a 3-pin. Obviously I don't care about color. Any ideas? And cheaper is better, as long as it's not as cheap as the stock one...
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (9TB partition for general storage + 2TB partition for dumping ground), 4x 8TB WD White Label/Red (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
OptiPlex 7040M
Intel Core i7 6700, 2x16GB Mushkin Redline (stuck at 2133MHz CL13), 240GB Corsair MP510, 130w Dell power brick, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
Pretty sure noctua makes 92mm fans. I know you said cheap, but hey.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
I know there is a Fractal one and a Noctua one, just too lazy to look up the SKU.
But, my grandma...
As long as it's under $15 USD (closer to $10, though), I think she won't mind.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I did the same thing to the same computer with this fan back and its not loud but has led's on it which may be annoying. Main reason was because it was antec and relatively quiet compared to the coolermaster one. http://www.newegg.com/Product/Product.aspx?Item=N82E16835209004
edit: the linked one does not include LED's
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
I'd go for either the Noctuas or Fractal's fans.
Quote me to get a reply!
Noctua one isn't 3 pin (her HP is weird, if it's a PWM fan connected to a regular 3-pin, it goes full speed).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
http://www.newegg.com/Product/Product.aspx?Item=N82E16835352005
This gets the silent part, dont know how much airflow you want. A jump in airflow will cost you some silence.
I'll think about that one.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Glad I could be of service.
speed reducers?
AAAAAAAAAGGGGGGGHHHHH!!!!
speed reducers?
Then it would still try and start then at 25% of whatever voltage they are capable of.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
