14 minutes ago, AydenF1 said:
I'm building my first PC and i have around probably 400-500 dollars for all of my parts. What are some cheap reliable parts I can use that can run a game like overwatch at a solid 60 FPS?
which country? need os/monitor/peripherals?
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355799
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355810
You can go with a combo of new and used parts and get better performance.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355854
8 minutes ago, AydenF1 said:
im in the US, i would probably need a mouse and a monitor.
PCPartPicker Part List
CPU: AMD Ryzen 5 1600 (12nm) 3.2 GHz 6-Core Processor  ($85.00 @ Amazon)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard  ($79.99 @ B&H)
Memory: Patriot Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory  ($38.99 @ Newegg)
Storage: MyDigitalSSD BP5e Slim 7 240 GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Video Card: XFX Radeon RX 560 - 896 4 GB Video Card  ($79.98 @ Amazon)
Case: Rosewill SRM-01B MicroATX Mini Tower Case  ($32.98 @ Newegg)
Power Supply: Corsair CV 650 W 80+ Bronze Certified ATX Power Supply  ($41.98 @ Newegg)
Monitor: AOC 22V2H 21.5" 1920x1080 75 Hz Monitor  ($79.98 @ Amazon)
Mouse: MSI Interceptor DS B1 Wired Optical Mouse  ($14.50 @ Amazon)
Total: $493.39
Generated by PCPartPicker 2020-03-07 22:45 EST-0500
i'd suggest looking around on ebay or criagslist for at least a few of the parts, $500 doesn't get you much when you also need a monitor.
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355892
Total: $493.39
scratch that, I have a monitor.
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355895
Memory: OLOy 16 GB (2 x 8 GB) DDR4-3200 Memory  ($62.99 @ Newegg)
Storage: Team L5 LITE 3D 480 GB 2.5" Solid State Drive  ($56.99 @ Newegg)
Video Card: XFX Radeon RX 570 4 GB RS XXX Video Card  ($129.69 @ Amazon)
Total: $504.12
Generated by PCPartPicker 2020-03-07 22:50 EST-0500
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355900
Total: $504.12
what if i make target price 400 instead?
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355905
then just follow the first list and remove the monitor.
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355917
A refurbished Dell Optiplex with a decent Intel i5 or i7 CPU with an SSD and windows 10 installed go for cheap, then all you may have to do is install a new GPU if the PSU will handle it, if not, a new PSU as well and an exhaust fan.
System specs below
PSU: Corsair CX650M
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355920
@AydenF1
Have to admit to you, it will be difficult to build a brand new computer worth its salt for gaming with only $500. At a minimum, you'll need at least $600, so if I were you, I'd post pone trying to build a PC and save up more money.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13355952
Hey @AydenF1 I'm currently building a pc for about $400. It's used though. Based on an optiplex 9020. However, it'll be able to run most, if not all new games on high settings. If you're interested, here's a link to my build:
Feel free to aks me more if you have questions. I think I'm getting pretty familiar with this platform lol. Been planning it for quite a while.
https://linustechtips.com/topic/1162831-first-ever-pc/#findComment-13356509
