sp 120 or nf f12 for cpu heatsink
vincent275
Hi, I'm currently using a hyper 212 evo and I'm thinking of swapping the stock fan for a better fan. Got eyes on corsair's sp120 and noctua's nf f12. Which one would be better and are there better options?
Well Nff12s are better and quieter but don't look as good
SP120s are still good but are a bit louder but look better
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
NF-F12
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
Noctua's will be quieter and have better static pressure. Corsair fans just look nice. If I can make a suggestion though, I would go for Gentle Typhoons.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
I'd go for the sp120 because you can get the quiet edition ones which are quieter, cheaper and they are not much worse the the noctua fans
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
Better as in what? Temps? Noise?
The NF-F12's will make it quieter but neither fans would help performance much.
as asked before in performance or noise or
both?
i believe this may solve a lot of public issues with both symtoms (noise and performance)
and in some cases the color of the fan.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200068
@12v 2.64mm/h2o @ 1300rpm - 57cfm - 16dBA for the rosewill/akasa PWM - $9.99USD
@12v 1.29mm/h2o @ 1450rpm - 38cfm - 23dBA for the corsair SP120QE PWM - $17.99USD
@12v 2.61mm/h2o @ 1500rpm - 55cfm - 22dBA for the Noctua NF-F12 PWM - $32.99USD
i got some of these last week and have been terrorizing the test case with them and
next the test bench. so far i am really impressed for the lack of noise and how well
the cooling aspect of these are and to boot, only $10. will know in a bit on thermal perf.
both?
thanks! I'll take a look of these
They should perform quite well. http://www.anandtech.com/show/6391/120mm-radiator-fan-roundup-part-2-fan-harder/7
NF-F12. There's no disputing the matter.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
