Gtx 1050 ti - i5 2400 vs i7 2600 noticable difference?
Solved by NunoBrandao,
This is easy to figure out.
Install MSI AfterBurner, Setup the HUD with stats of CPU load and GPU load.
Which one is at 100%? GPU, CPU, Both?
If GPU is at 100% "upgading" the CPU will give you a bit of improvement but not much.
Is CPU at 100% and GPU not? GPU is waiting for CPU so CPU "upgrade" will help.
Etc
I think you see the point.
