Question: Do I need a new case or cooler.. or both?
Case: NZXT h510
Cooler: Cooler Master Hyoer 212 rgb black edition
Im almost done with my build however while I was buying all my parts I went from a budget 1000$ build to about a 2300$ build. I heard the h510 has heating problems, and it isnt the quietest thing ever which isnt to much of a problem itself. I heard the cooler is great but I dont know if I should switch to a liquid cooler "x62 Kraken" in my case. I am running 32gb of ram with a 9700k and a 2070 super. Refer back to question.
https://linustechtips.com/topic/1161754-please-help/
If you plan on overclocking I'd go with a high end air cooler and get rid of the 212.
https://linustechtips.com/topic/1161754-please-help/#findComment-13346309
12 minutes ago, The_Geek said:
best I have found for airflow:
Cooler Master MCM-H500-IGNN-S00 MasterCase ATX Mid-Tower w/ Tempered Glass Side Panel, Transparent/ Mesh Front Option, Carrying Handle And 2x 200mm RGB Fans w/RGB Controller
If I purchase this case can I keep my cooler master hyper 212?
https://linustechtips.com/topic/1161754-please-help/#findComment-13346380
The Case has excellent air flow.
You can keep your current Cooler, But the N15 is a better cooler, and since I have both, I can say that the cooler tower height is OK.
Use the3 mesh front and not the acrylic one that comes in the box.
Do you plan on Overclocking the shit out of this setup?
https://linustechtips.com/topic/1161754-please-help/#findComment-13349056
I thought about it but honestly no
https://linustechtips.com/topic/1161754-please-help/#findComment-13355484
On 3/8/2020 at 10:53 AM, The_Geek said:
:o. It was just a suggestion and a personal choice and experience... but I am curious.. what is your thought process..?
Build my pc, have fun with it and it last for a lonnng while before I upgrade it. Once I upgrade it id overclock it
https://linustechtips.com/topic/1161754-please-help/#findComment-13367619
