Hi,
I have gigabyte rtx 2080s gaming, the card idle temps starts early 30s, after couple of minutes the card reaches 55 which makes the fans spin to cool, then fans stop spinning when reach 54 then back to spin at 55 and so on, it very annoying...
temps while gaming is very reasonable, doesn't exceed 70c @60% fan speed.
https://linustechtips.com/topic/1161500-high-idle-temps-2080s/
Change the fan curve.
https://linustechtips.com/topic/1161500-high-idle-temps-2080s/#findComment-13344007
You could also change its Power Management Mode to Optimal Power.  That can be found in NVIDIA Control Panel under Manage 3D Settings.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1161500-high-idle-temps-2080s/#findComment-13344024
