Please help me identify this case
Go to solution Solved by Eschew,
Hello. Seems like the Yeston brand sells/supplies the case:
Sourcehttp://www.yeston.net/product/details/272/290
Looks like a 3-D printed custom enclosure built around one of those big open-frame cases, like the Cougar Conquer (although it is definitely not a Conquer). The GPU shroud also looks 3-D printed.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
GN likes to tease their next content piece by having the subject on the table in clear view, look forward to their next couple vids or so.
Primary PC:
PSU tier list
How many watts do I need?
I would guess its something from Aliexpress, much like the Waifu GPU that bears the same or extremely similar cat face design. Its likely a case from the same manufacture, but a quick search of Aliexpress and I couldnt find one personally.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
正直に生きる、一度きりの人生だから
Keeb Weeb LinksCustom Mechanical Keyboards | #KeebWeebClub
'Chew Builds: Hoshī (PC) | Okashī (PC) | K-4398 (Keeb) | Eighty #391 (Keeb) | R2-968 (Keeb) | MGK64 (Keeb)
