It's not much but it's mine
This beasts makes csgo runs at 720p with 40 fps ?
 When i started it the first time i smelled something burning but it was just my processor over-heating because a cable was stuck in the fan ?
But look at this beauty
I tryed to install a graphic card but for what use ? It's not just because it doesn't have an pci-e cable, my integrated gpu is amazing ?
can't belive the A8-9600 is this powerfull
https://linustechtips.com/topic/1160367-my-cable-management-20/#findComment-13334664
27 minutes ago, Murasaki said:
First time I see a banana sata cable, guess it fits well with the mustard and ketchup psu cables.
Yeah it's pretty recent ?, i understand it's impressive to see all those next gen cables at the same time, so recent that it doesn't even have any pin cable for graphics cards, the futur is for integrated gpu ?
Maybe consider selling your graphic cards while they are still worth something
https://linustechtips.com/topic/1160367-my-cable-management-20/#findComment-13334738
Guest
