LCD display acm
RexLee
Go to solution Solved by Ciccioo,
LC displays are made of 7 segments, like this
so, for each digit you have to display, you need to know how to "draw" the 7-segments version of it
you can do this by just storing the on/off state of each segment for each digit, or you can do it like it's done in the solution you found and store what to draw in the place where the segment is
edit:
it's shortly explained in the code too, am i missing the part that you actually didn't understand?
The problem is: http://uva.onlinejudge.org/index.php?option=com_onlinejudge&Itemid=8&page=show_problem&problem=647
But the way I solved it isn't efficient.
So I found a solution on the web: http://code.google.com/p/acm-uva-ufrgs/source/browse/trunk/%20acm-uva-ufrgs/Problem%20Set%20Volumes/Volume+VII/706.c?r=2
But I don't understand the conversation table in the source code.
edit:
