Cryorig XT140 Ticking Noise
Stipz
It's making a ticking sound similar to when a drive needle is acting up during a read cycle, one of the scariest things I don't like hearing from my PC.
I thought at first it was either of my hard drives creating the noise because those are fairly new and not much data has gone through them.
I was able to isolate the noise and surprised to find out that it was coming from my CPU Cooler which is a Cryorig R1 Universal
the noise is coming from the thin fan, the XT 140, I unclipped it from the heatsink and checked the axle lock,
that thin plastic washer that keeps the bearings in and prevent them from coming off has loosened.
I flattened the plastic washer and put it back in and the noise is gone, a day later it's making a noise again and most likely the washer came off again.
Not sure if taking a plastic washer from a different fan would solve the problem because I'm think it's likely to come off again since it's of the same material.
I'm thinking of other ideas for a fix at the moment, maybe someone else had this problem too and I would like to know how others repaired theirs.
Nova B.R.E.A  - (Binary Remote Electronic Assistant)
Main Parts
Intel Core i7-9700k @ 4.3Ghz - Cryorig R1 Universal - AsRock Phantom Gaming 9 - T-Force Nighthawk 8gb x 2 @ 3200Mhz
GALAX GTX 1070 Ti - Cooler Master H500P White - Corsair RM 750x
Storage
ADATA SX8200 256 Gb - GIGABYTE UD Pro 256 Gb - Western Digital Blue 1 Tb - Western Digital Blue 4 Tb
Peripherals
Dual PHILIPS 246E7QDSW 23.6" IPS/PLS Panel - Logitech Z313 - Corsair Void Pro RGB White wireless - Redragon YAMA K550W
Roccat Nyth - Wacom Bamboo Pen&Touch 4x6"
overbending this plastic washer somehow fixed it. It's no longer coming off to make that ticking noise again so far. I'll look into making a clip lock by bending paperclips if those could work.
Main Parts
Storage
Peripherals
If its still under warranty, RMA. They should accept that for just fan.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I don't have too much experience with the XT140, but I have had bearing issues with its big brother XF140. Cryorig was very responsive and very quick with the RMA.
Aerocool DS are the best fans you've never tried.
