Hellow. im new and  im trying to put  gaming rig. i got litle buget so i cant go crazy. i got me
  AMD ryzen 5 1600 6x3.2
Gigabyte GA-AB350 Gaming 3 Mainboard AMD B350 AM4 Dual Channel ATX bis 64GB Ram.
im not sure if i can put the ram in wich i chosen -16GB (2x8GB) DDR4 3000 MHz PC4-24000 LEVEN RGB Gaming Arbeitsspeicher Kit PC.
for the case i pickt up SaharaGaming H600B E-ATX/ATX/M-ATX/ITX. Supports max. 360 mm water cooling, 20/14/12 cm fan, 4 x 2.5 inch SSD and 3 x 3.5 inch HDD, video card length 380 mm and CPU 188 mm height
and i  got Radeon rx 580 8gb   on sale.
For the storage i got ssd M2 but im not sure. for that stands the 22110 suport on motherboard.
Im realy not sure abauth ram. mybe can you tell me if the ram and ssd M2 will fit the build?
Storage - 256GB Samsung PM981 M.2 SSD MZVLB256HAHQ-00000 (2280)
Sory for my englis im not the  English persone. and i know im not goot at it sory agen.
https://linustechtips.com/topic/1160024-need-help-for-new-build/
In order to see what fits and is already tested in a motherboard you need to go to the QVL of the motherboard. In your case here:
 https://www.gigabyte.com/us/Motherboard/GA-AB350-Gaming-3-rev-1x/support#support-dl
Ofc, if something is not in there it doesn't mean it won't work but you get yourself into possibly manual tuning, failure of compatibility etc. Just avoid it since you don't seem very familiar with those things
I looked for the leven ram and they are not there as expected. To be honest I don't even know this brand. At this price you can way better and more trusted ram kits!
M.2 will be fine.
That's about it
o oky. ty. if the ram wont work i can send it back to ebay. . i  know you dont need more then 16 gb ram for games. its alredy owerthe line :D.
i was more   in panick bicose theres a non ecc and ecc / and other type of ram. so i dont know wich one i need for this bicose i reded i cant put  ecc in non ecc motherbord, i understand froem videos.
Than probably this ones woud be bether i know the brand .
Corsair Vengeance RGB PRO 16GB (2x8GB) DDR4 3000MHz C15 LED Desktop Memory - B..
ram that works is not always on the list. I have G.Skill Trident Z Royal in mine and it is not listed for my board.
OS: Microsoft Windows 10 Pro, Motherboard: ASUS Crosshair VI Hero, CPU: AMD Ryzen 5 3600, Heat Sink: AMD Wraith Prism RGB, Video Card: FTW GeForce RTX 3080, Memory: 4 x G. Skill Trident Z RGB Royal 8GB (total 32GB), Power Supply: Thermaltake Tough Power Grand RGB750W, MonitorAOC Q32G1WG4, HD: 2 x Samsung EVO 850 and 4 x Seagate 2TB ST2000DL 003-9VT166 SATA HD, Keyboard: G. Skill RipJaws KM780R RGB Mechanical Keyboard, Mouse: Logitech G903 Wireless, Network Adaptor: D-Link DWA-192 AC1900 Wi-Fi USB 3.0
woot. i got it runing. aperently it was  i didnt put inaf force on ram..  and i prest in bios batery on borad mybe it was   not conencted.
#WOoot i got my ryzen adn all yeaa .. ty for the suport page. it wil realy help i need newest bios dowloadn and all drivers .:D ty..
1 minute ago, JoKe12s said:
okj im so confused right now. im lokingin dxdiag at my pc and is ses amd ryzen 5 1600 (12 cpu)  3.2 wtfk
seems right (not sure what you mean by 3.2 though)
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
2 minutes ago, JoKe12s said:
3.2 ghz
Wait but its 6 core cpu..  esy 12 cpu? sory im new to ryzen . my old pc was liek 8 years old amd atlon 4 core
It has 6 cores and 12 threads and runs at 3.2ghz
no worries
the funy i got gaming laptop acer Nitro 5 . and this 450 buks pc beats it :D:D  i was suprised wen i plug in my laptop to my  tv it sed this device dont suport 4k . iwas like wow. i  dowloand  drivers for the radeon rx 580 it emedlty offers turn 4k on :D . yea gaming laptop:D only gaming is the word in laptrop  in store wen it  is on sale..
no worries
ty alot for info , hmm mybe you can tell my do i need all bios updates or no ? i understand froem videos abauth pc best is wen bios is the latest version. so it  run bether. i think i got last year 06/19  bios
yeah, laptops tend to run slower than pcs tbh I've found
and the heat. i tryed runing 7 days to dei on mid . the saudn the fans go off liek turbo mode is offul.
yeah, I know that feeling 9had a pentium laptop at one time (around 2014-2016)  If I put it under max load it was pretty loud lol
7 minutes ago, JoKe12s said:
im now thining if this pc wich i build is cable of runing vr? or even suport vr? bicose i got oculus rift s but i cant put it on my laptop dont suport Displayport or usb type c tunderbold. it have only hdmi adn type c charging :(
what sort of display inputs does the oculus have?
dispay port. the rx 580 have 3 dispayports but dose it suport vr gaming?
yeah it should support it Don't use  vr myself though so I'm defitionally not an expert on it
