Specs:
ASRock B450M Pro4-F
AMD Ryzen 5 3600
Nvidia GTX 1050ti (used)
16gb (dual) ddr4 3200 Klevv Cras X RGB
256gb Adata XPG SX8200 Pro SSD M.2 NVMe
2tb Seagate Barracuda 7200rpm
Silver Stone SST, 550watts, Strider Essential, PSU, 80PLUS gold
Tecware Alpha (used)
Dell 24' IPS monitor (used)
So I installed everything properly and I thought everything was running fine when the fans started spinning and the RAM light up but it displayed nothing on my monitor. Another thing to note is that it seems that it's booting fine because the NumLock on the keyboard responds.
I used an HDMI 2 volts cable inserted to the GPU. I also tried plugging it to the motherboard, and also tried a VGA cable. Nothing happened. The available ports for the monitor are DVI and DisplayPort (and among others) and I haven't tried it yet.
I reseated every part but to no avail. Also changed the CMOS battery. Still, nothing happened. Plugged my CPU to a direct power outlet, still nothing.
I suspect that this may be from the motherboard's BIOS (which I can't flash because there's no display), or this may be a compatibility issue with B450 boards and 3rd gen Ryzens. Another possible problem is from the GPU (I already cleaned it, changed the heatsink, reapplied thermal paste) and from the cables or the monitor itself. Any tips on how to fix this?
Edited by Serftion
https://linustechtips.com/topic/1159012-pc-wont-post/
2 minutes ago, xhackforeverxdx said:
I am pretty sure your Board needs a Bios update to work with 3th gen Ryzen did u buy it new or is it a used board if its new its possible that the bios version is to old
The board is brand new. It said on the box that it is Ryzen 3rd gen ready so I didn't really think I'll run into this problem. We haven't tried this yet so maybe this might do it
https://linustechtips.com/topic/1159012-pc-wont-post/#findComment-13323335
try 1 stick of ram and alternate maybe on is bad.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1159012-pc-wont-post/#findComment-13323338
https://www.asrock.com/news/index.asp?iD=4238
Its true that it works with the ryzen 3000 series chips but looking onto there website your Board is listed needing a Bios update for that ( i mean your board could be sitting in the store for a year )
https://linustechtips.com/topic/1159012-pc-wont-post/#findComment-13323343
Tried that already, still nothing
I guess so. I will try updating my bios as soon as possible. Thank you!
https://linustechtips.com/topic/1159012-pc-wont-post/#findComment-13323354
On 2/25/2020 at 9:17 AM, Serftion said:
Specs:
ASRock B450M Pro4-F
AMD Ryzen 5 3600
Definitely the GPU. The 1050ti is getting pretty old now so you were in a need of an upgrade anyways.
https://linustechtips.com/topic/1159012-pc-wont-post/#findComment-13326312
