Hi Linus
Hope you are doing well,
I am starting this topic i need your help
https://youtu.be/xAP1a1H0Mg0
I watched this video i wanted to make a PC like this for my work as i am a web developer and graphics designer and have a budget of 500 - 900 $ but am from pakistan and don't know much about PC building and also wanted to i emailed you twice for seeking help.
Waiting from your side answer.
https://linustechtips.com/topic/1158529-need-help/
4 minutes ago, Ali Hamza said:
Hi Linus
Keep in mind Linus and staff from LinusMediaGroup doesn't often post here, it's mostly forum members that do.
If you're on a tight budget and want a good PC, it's probably not worth it to go for a desk PC like this. You're basically spending a ton of money on the materials and tools to make it, while the alternative would be a plain PC case for 30-90 USD.
If you want recommendations on the sort of PC you're building, people can certainly help you with picking out parts here. Just mention the sort of things you want to do on the PC (like is it a gaming machine, or is it only for web dev and graphics design? What games/programs? etc.)
https://linustechtips.com/topic/1158529-need-help/#findComment-13319409
6 minutes ago, Ali Hamza said:
Well being under budget what will you guys will suggest me like I am a graphics designer most of the work is done in Adobe illustrator and Some animations in After Effect. Most of the time working as a Back-End Developer and Gaming for stress relief
A build like this would do:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Amazon)
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard  ($89.97 @ Amazon)
Memory: *OLOy WarHawk RGB 32 GB (2 x 16 GB) DDR4-3200 Memory  ($124.99 @ Newegg)
Storage: ADATA XPG SX8200 Pro 512 GB M.2-2280 NVME Solid State Drive  ($79.98 @ Amazon)
Storage: Western Digital Blue 2 TB 3.5" 5400RPM Internal Hard Drive  ($53.99 @ Newegg)
Video Card: EVGA GeForce GTX 1660 Super 6 GB SC ULTRA GAMING Video Card  ($228.98 @ Newegg)
Case: Fractal Design Focus G Mini MicroATX Mini Tower Case  ($54.99 @ Amazon)
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $897.88
Generated by PCPartPicker 2020-02-23 16:33 EST-0500
The combination of a good CPU, with some more cores than most, a videocard which can do hardware acceleration (CUDA), 32GB of RAM of the heavier vector tasks and After Effects would help too.
Of course a fast SSD, around 500GB to even give you some space to store current project on, but another HDD is a good to have too. Of course do look into a good backup solution, so mission critical information is not stored on just one drive in your PC.
This is the sort of PC I would recommend for your use case.
https://linustechtips.com/topic/1158529-need-help/#findComment-13319434
