I've never built a custom loop, so I could be right out to lunch, but I don't believe there should be any bubbles at all. Distro plate or not.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1156985-distro-plate-problem/#findComment-13307236
1 hour ago, ChrisZH said:
I've had tiny bubbles before, but that was with a res not a distro. I'm wondering if my pump is just too strong?
If I recall you cleaned your loop recently, was it properly rinsed out before refilling? That looks very much like detergent or soap bubbles and not just from turbulence from filling.
https://linustechtips.com/topic/1156985-distro-plate-problem/#findComment-13307425
Yes, I cleaned my gpu block but rinsed thoroughly with distilled water. Other than that, the tubes that I bent used Dawn as lubricant. But after every bend I washed the tubes once they were correct length.
https://linustechtips.com/topic/1156985-distro-plate-problem/#findComment-13307823
2 hours ago, ChrisZH said:
What coolant is this? or is this just distilled water?
https://linustechtips.com/topic/1156985-distro-plate-problem/#findComment-13308027
Might be some residual dawn soap or something reacting with the fluid if it's coolant in the loop.
https://linustechtips.com/topic/1156985-distro-plate-problem/#findComment-13308355
lightly tap the tubes with a screwdriver or pen and watch the tiny bubbles float away. I had that on my first fill (albeit not quite as extreme as this) but they shifted pretty fast after I tapped around the tubes
I would agree this looks more like residue to have as many but give it a try and see what happens
https://linustechtips.com/topic/1156985-distro-plate-problem/#findComment-13308459
