Audio from mixer to pc and console.
Marsir
I am using a Yamaha MG10XU mixer board and an xlr mic. I have the mixer configuration to usb to my pc and it works great no problems at all. However when trying to send my mic audio through fx send (yes the fx nob is turned on) I get a very noise line and if any voice at all it's way distorted and grainy plus to loud. I have tried connecting from fx send to a usb converter to mic and nothing worked. I also then tried to plug it just into the controller and again nothing. I am only using a 3.5 audio cable male to male one side into a converter that makes it quarter inch into the board and a saberent usb audio interface to the ps4. When I connect the line coming from the mixer to a pair of headphones it sounds perfect no issue at all but anytime I connect it to the ps4 it's just loud static and distortion. Any suggestions? I have been trying to figure it out for hours now and I am still scratching my head any ideas or help is very much appreciated thank you in advance.
Only thing I can think of is some issue with that port on the ps4 or a bad cable somewhere
