Controlling Kraken X73 Fan Speed
I currently am using the Kraken X73, which is my first watercooling ever. I run a X3950 with it so I wanted to have the thermal mass, also because I want to use it with the Dune Pro case eventually.
That being said, I can put up curves for my pump in CAM just fine, but my fans simply don't show up. I connected it to the CPU-fan header, pump to pump-header, and used a splitter for the fans (since there are three) externally powered through a sata-connector (I have NO idea why this wasn't included for the price).
Now, the issue is, my fans jump up and down with temp spikes, which tend to vary every few seconds, so they are linked to CPU temp rather than water temp. Can't seem to set up the system to use water temp instead for some reason.
I am running it all on an MSI X570-Pro if that helps, but pointers would be cool.
