Ive come to the conclusion that my next evolution into my PC hardware journey is getting a proper test bench.  Now I do have some unused PC cases - if its easy enough I can DIY one from the mobo tray etc using a Dremel or whatever please do tell me that it works well doing this and I will save the coin on buying a test bench but if it turns out to be a lot of work for an ugly test bench (I have a $17 case I could bastardize for example) Id rather just buy something like this:
https://www.amazon.com/Overclock-Computer-Aluminum-Chassis-Graphics/dp/B07YYXJFG4/ref=sr_1_3?keywords=test+bench&qid=1581440587&sr=8-3
https://www.amazon.com/Motherboard-Transparent-Acrylic-Overlock-Computer/dp/B07KXMNZC1/ref=sr_1_7?keywords=test+bench&qid=1581440587&sr=8-7
https://www.amazon.com/Frame-Motherboard-Overclock-Computer-Chassis/dp/B07YZ15XTP/ref=sr_1_17?keywords=test+bench&qid=1581440587&sr=8-17
Id even be interested in snagging up a chinesium mining frame if it will work the same (I have one, but its in use as a miner rig, and I don't see why it shouldn't be an option but for me its to big to be an option...unless someone says hey theres a good reason to consider it!)
Any advice on what to look for in a test bench?  I actually want to get into liquid cooling with tubs of ice outside for OCing adventures and if you have experience with a test bench you highly recommend especially for this sort of application please let me know!  Worse case I save up a bit instead of getting a cheap one.
But if they are mostly the same, Id prefer to just buy a cheap version.
Thank you for your time
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1154515-recommend-me-a-test-bench-please/
9 minutes ago, Tristerin said:
I chopped up and bent a FD Define C as an angled test bench, it was pretty cool. But I had to throw it away before moving countries unfortunately. I do also have a Streacom BC1 which is an absolute marvel of engineering and it packs down so well that it was allowed to move with me.
Looks better than I expected and Im glad to see what cuts you took.  Thank you for this perfect reply.  Im on the fence as the case I have is super cheap so Im not sure it can withstand the bends/support itself without additional modding and jankiness (which I approve of) so I may end up getting one from Amazon.
The other part of me says, its a $17 case - do it.  I will report back!
