memtest86 results needed help
Go to solution Solved by mariushm,
I would test each memory stick by itself and see if you still get errors.
Install one stick, test, if you get errors  move stick in 2nd slot and test again.
If you get errors in any slot, then it's the stick that's faulty.
If you get errors only in a particular slot, then it could be the memory slot is actually faulty.
Repeat the process with the 2nd stick and other sticks you have.
Hi,
i had built my first pc recently,  and while playing a few games it used to close itself randomly without any errors. (Mostly playing cs:go online).  I had done the windows memory diagnostic test which said memory is ok.
Today i did a memory diagnostic test and i have shared the results in both html and a screenshot version incase the html doesnt open.  So my replacement period for the parts end by about tomorrow, and im wondering if i should have it replaced. Or maybe there can be issues with the motherboard as well or any part i feel at the moment. Not sure about any part at the moment.
MemTest86-Report-20200211-171302.html
https://linustechtips.com/topic/1154442-memtest86-results-needed-help/
Your tests show a lot of errors and you're wondering if you should just continue using broken RAM?
yea i will be replacing,  strangely i didnt get any errors testing each stick by itself and in different slots. Also tried testing with xmp disabled and i got 0 errors.
Second round of testing with xmp enabled gave me 27 errors but i guess i didnt save it. Going to go for one more test run before replacement and will post the result.
Ok im replacing it with thermaltake tough ram 16gb 2 sticks of 8gb.  3200mhz
i was also considering buying hyperx fury 3200mhz. But i was only getting single sticks of 8gb no kit and thermaltake was delivering faster.
So i was wondering when i did the memtest86 without XMP enabled   i didnt get any errors on 1 passes,  does that mean by motherboard and cpu are not faulty?
replaced the ram, did 4 passes on new one. getting no errors.  Thanks for helping out.
Summary
Report Date 2020-02-16 07:29:42
Generated by MemTest86 V8.3 Free (64-bit)
Result PASS
System Information
EFI Specifications 2.70
System
Manufacturer Gigabyte Technology Co., Ltd.
Product Name B450M DS3H WIFI
Version Default string
Serial Number Default string
BIOS
Vendor American Megatrends Inc.
Version F50
Release Date 11/27/2019
Baseboard
Product Name B450M DS3H WIFI-CF
Version x.x
CPU Type AMD Ryzen 5 2600X Six-Core
CPU Clock 3630 MHz [Turbo: 3629.9 MHz]
# Logical Processors 12
L1 Cache 12 x 96K (80372 MB/s)
L2 Cache 12 x 512K (66266 MB/s)
L3 Cache 1 x 16384K (30804 MB/s)
Memory 16347M (18045 MB/s)
DIMM Slot #0 8GB DDR4 XMP PC4-25600
  Thermaltake Technology Co Ltd / R009D408GX2-3200C16A
  16-18-18-38 / 3200 MHz / 1.350V
DIMM Slot #1 8GB DDR4 XMP PC4-25600
Result summary
Test Start Time 2020-02-16 00:33:11
Elapsed Time 3:42:22
Memory Range Tested 0x0 - 41F380000 (16883MB)
CPU Selection Mode Parallel (All CPUs)
ECC Polling Enabled
# Tests Passed 48/48 (100%)
Test # Tests Passed Errors
Test 0 [Address test, walking ones, 1 CPU] 4/4 (100%) 0
Test 1 [Address test, own address, 1 CPU] 4/4 (100%) 0
Test 2 [Address test, own address] 4/4 (100%) 0
Test 3 [Moving inversions, ones & zeroes] 4/4 (100%) 0
Test 4 [Moving inversions, 8-bit pattern] 4/4 (100%) 0
Test 5 [Moving inversions, random pattern] 4/4 (100%) 0
Test 6 [Block move, 64-byte blocks] 4/4 (100%) 0
Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
Test 8 [Random number sequence] 4/4 (100%) 0
Test 9 [Modulo 20, ones & zeros] 4/4 (100%) 0
Test 10 [Bit fade test, 2 patterns, 1 CPU] 4/4 (100%) 0
Test 13 [Hammer test] 4/4 (100%) 0
