Netbeans install error (problem with Java JDK)
Solved by C2dan88,
You are using the Java 13 Runtime (JVM / JRE).
Netbeans requires the JDK (development kit) installed too. I think the JDK needs to be same version as the JVM/JRE you are using. You only have openjdk-11 installed. Maybe try install java13 JDK and setting your JAVA_HOME environment variable to java13 jdk install path
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
3
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8
play_circle_filled
Latest From ShortCircuit:
