Hello guys i was just doing some edditing and i had a lot of tabs open and then i noticed thats something is going wrong so i check ryzen master and i saw that my PPT and EDC is too high and RED so i was wondering what to do to change that and run low and smouthly. I have gtx 1060 6g and 550W psu
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/
all I’ve got for you is definitions of acronyms I’m afraid.  Might be useful, might not.  There are people who will understand this better than me.  I’m just trying to facilitate a bit.
Ppt= apparently stands for “package power tracking” and can go up with high thread counts, which makes sense with bunches of tabs open.
edc= “electrical design current” which has to do with how much current your motherboard voltage regulator configuration can put out.  I think.
Im guessing your cpu wants more voltage than your motherboard can provide or is set to accept from the motherboard? Maybe? Not sure.
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275314
7 minutes ago, Panosof said:
so... buying a new psu with more W we be helpfull!
I did not say that.  Didn’t mention the PSU at all in fact.  I actually rather doubt PSU wattage capacity has anything at all to do with this.  I could be wrong of course.
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275346
Which motherboard do you have?
Seems like a limitation of the mobo, using an A series by chance?
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275506
Just now, Panosof said:
i have Asus TUF GAMING X-570 PLUS
Then something is screwy in the bios. My numbers are way higher than those.
If you go to the bios and check AMD overclocking, and check precision boost overdrive, it should be set to Advanced. and leave the rest at default settings.
— Grumpy old man
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275524
1 minute ago, Panosof said:
But that's why I said I need new psu
OOOF!
You need have the 8 pin connector plugged in. 4 pin is for additional power for overclocking (not needed). but you NEED the 8 pin connected,.
— Grumpy old man
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275526
Just now, miagisan said:
OOOF!
You should at least have the 8 pin connector plugged in. 4 pin is for additional power for overclocking (not needed). but you NEED the 8 pin connected,.
yes my psu at this point doesnt have.. this is why i said i need an upgrade
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275527
Yes, in fact i wouldnt run the computer just on the 4 pin. Its not getting the power it needs and cant guarantee its health.
— Grumpy old man
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275534
curious on how your PSU doesnt have an 8 pin cable, thought that was an ATX standard.
— Grumpy old man
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275537
The impression I am getting is that the problem with the PSU is not wattage, it is cable connections.  The make/model of the PSU so far has not been mentioned.  Perhaps this is important.  This could be a situation where the PSU has the required connectors and is merely plugged in incorrectly.
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275545
Should still have an 8 pin cpu connector. It's not that old
— Grumpy old man
https://linustechtips.com/topic/1152787-reduce-temperature-cpu/#findComment-13275561
