Using a NAS over wifi
Solved by LIGISTX,
On 2/6/2020 at 2:44 PM, oscarmorgan said:Hey,
Thanks for your reply, it will just be 8tb running in raid 1. It has a i5-4590 and 8gb of DDR3 and will only be used by me sort of as a place to dump all my old projects, (around 10gb each). I understand it wont be crazy fast but what sort of speeds could i expect?
Cheers
Wifi can be faster then gigabit depending on the situation. But, it’s extremely unlikely that will actually be the use case you end up with. But it should be “fine”.
