Router causing bandwidth issues for Local IP Cameras
54 minutes ago, Windows7ge said:You can try it if you like but my expectation would be that it won't make an improvement. There's well in excess if available bandwidth (unless the router is 100Mbit). Sounds like the issue is something else. What exactly I can't say.
Might try unplugging 3 cameras and see what happens as you add each camera. How the problem changes. May just be one camera doing something weird.
Good suggestions. I'm more inclined to think it's probably the PC. @A.Hruskach I would check CPU usage and HDD usage on the PC when all 4 cameras are recording footage. Even at max bandwidth, 4x 8Mbps = 32Mbps (4 MB/s).
So even if the Router is limited to 100Mbps, you'd still have around 2/3rds spare bandwidth for other traffic. And any HDD, even an older one, should be able to handle 4 MB/s of disk recording.
So my suspicion would be that the HDD is going bad, or there are possible issues w/ the OS itself (possibly other hardware failure).
But, also follow @Windows7ge's advice, and test each camera one at a time, to see if you get the same issues on one of them. If each one individually works fine, pair 2 together. Then 3, etc. And see if you can pinpoint exactly what combination is causing the issues.
